Time Before: 0.00214 seconds
Time After: 0.00313 seconds
Time Taken: 0.00099 seconds
Time Before: 0.00323 seconds
Time After: 0.00381 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00407 seconds
Time After: 0.00423 seconds
Time Before: 0.00509 seconds
Time After: 0.00741 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00430 seconds
Time After: 0.01205 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01441 seconds
Time After: 0.01495 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01748 seconds
Time After: 0.01872 seconds
Time Before: 0.01365 seconds
Time After: 0.01898 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02676 seconds
Time After: 0.02693 seconds
Time Before: 0.02951 seconds
Time After: 0.03075 seconds
Time Before: 0.03529 seconds
Time After: 0.03546 seconds
Time Before: 0.03847 seconds
Time After: 0.03997 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1788875186, location = '/forums/private.php?do=newpm&explain=1&u=23622' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05770 seconds
Time After: 0.05804 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
