Time Before: 0.02368 seconds
Time After: 0.03092 seconds
Time Taken: 0.00723 seconds
Time Before: 0.03103 seconds
Time After: 0.03154 seconds
Time Before: 0.03183 seconds
Time After: 0.03198 seconds
Time Before: 0.03286 seconds
Time After: 0.03495 seconds
Time Taken: 0.00208 seconds
Time Before: 0.03206 seconds
Time After: 0.03908 seconds
Time Taken: 0.00702 seconds
Time Before: 0.04596 seconds
Time After: 0.04636 seconds
Time Before: 0.04906 seconds
Time After: 0.05031 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04523 seconds
Time After: 0.05058 seconds
Time Taken: 0.00536 seconds
Memory After: 2,261.836 KB
Time Before: 0.09400 seconds
Time After: 0.09415 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.21539 seconds
Time After: 0.21664 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.22737 seconds
Time After: 0.22752 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.22986 seconds
Time After: 0.23130 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789041024, location = '/forums/private.php?do=newpm&explain=1&u=23631', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.24980 seconds
Time After: 0.25009 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
