Time Before: 0.01987 seconds
Time After: 0.02468 seconds
Time Taken: 0.00481 seconds
Time Before: 0.02477 seconds
Time After: 0.02525 seconds
Time Before: 0.02549 seconds
Time After: 0.02571 seconds
Time Before: 0.02646 seconds
Time After: 0.02837 seconds
Time Taken: 0.00191 seconds
Time Before: 0.02576 seconds
Time After: 0.03237 seconds
Time Taken: 0.00662 seconds
Time Before: 0.04012 seconds
Time After: 0.04055 seconds
Time Before: 0.04306 seconds
Time After: 0.04429 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03946 seconds
Time After: 0.04452 seconds
Time Taken: 0.00506 seconds
Memory After: 2,261.836 KB
Time Before: 0.07296 seconds
Time After: 0.07316 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09664 seconds
Time After: 0.09794 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.099919080734253
Time Before: 0.10732 seconds
Time After: 0.10756 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10998 seconds
Time After: 0.11147 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789104220, location = '/forums/private.php?do=newpm&explain=1&u=23659', badlocation = 1
Time Before: 0.13065 seconds
Time After: 0.13089 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.12966418266296 seconds with 9 queries, spending 0.0077426433563232 doing MySQL queries and 0.12192153930664 doing PHP things.
