Time Before: 0.00152 seconds
Time After: 0.00217 seconds
Time Taken: 0.00065 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00224 seconds
Time After: 0.00296 seconds
Time Taken: 0.00072 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00333 seconds
Time After: 0.00352 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00426 seconds
Time After: 0.00692 seconds
Time Taken: 0.00266 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00359 seconds
Time After: 0.01034 seconds
Time Taken: 0.00675 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01225 seconds
Time After: 0.01270 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01545 seconds
Time After: 0.01673 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01151 seconds
Time After: 0.01699 seconds
Time Taken: 0.00548 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02346 seconds
Time After: 0.02366 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02560 seconds
Time After: 0.02686 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.028523921966553
Time Before: 0.02977 seconds
Time After: 0.02997 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03194 seconds
Time After: 0.03341 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=23683'
Time Before: 0.05219 seconds
Time After: 0.05250 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.051293849945068 seconds with 9 queries, spending 0.0087301731109619 doing MySQL queries and 0.042563676834106 doing PHP things.
