Time Before: 0.00830 seconds
Time After: 0.01019 seconds
Time Taken: 0.00189 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01030 seconds
Time After: 0.01074 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01098 seconds
Time After: 0.01111 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01198 seconds
Time After: 0.01423 seconds
Time Taken: 0.00225 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01118 seconds
Time After: 0.01849 seconds
Time Taken: 0.00730 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.02220 seconds
Time After: 0.02258 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.02387 seconds
Time After: 0.02505 seconds
Memory Before: 2,771.641 KB
Memory After: 2,771.500 KB
Time Before: 0.02152 seconds
Time After: 0.02524 seconds
Time Taken: 0.00372 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.531 KB
Time Before: 0.04134 seconds
Time After: 0.04151 seconds
Memory Before: 3,437.641 KB
Memory After: 3,438.156 KB
Time Before: 0.04813 seconds
Time After: 0.04937 seconds
Memory Before: 3,525.438 KB
Memory After: 3,526.031 KB
Time Before: 0.05513 seconds
Time After: 0.05532 seconds
Memory Before: 4,163.305 KB
Memory After: 4,163.734 KB
Time Before: 0.05790 seconds
Time After: 0.05936 seconds
Memory Before: 4,444.867 KB
Memory After: 4,446.555 KB
UPDATE session SET lastactivity = 1776547134, location = '/forums/private.php?do=newpm&explain=1&u=23684' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.07619 seconds
Time After: 0.07657 seconds
Memory Before: 4,918.703 KB
Memory After: 4,918.930 KB
