Time Before: 0.00187 seconds
Time After: 0.00242 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00250 seconds
Time After: 0.00303 seconds
Time Before: 0.00330 seconds
Time After: 0.00341 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00416 seconds
Time After: 0.00813 seconds
Time Taken: 0.00397 seconds
Time Before: 0.00346 seconds
Time After: 0.01156 seconds
Time Taken: 0.00810 seconds
Time Before: 0.01404 seconds
Time After: 0.01445 seconds
Time Before: 0.01704 seconds
Time After: 0.01831 seconds
Time Before: 0.01342 seconds
Time After: 0.01858 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02577 seconds
Time After: 0.02599 seconds
Time Before: 0.02939 seconds
Time After: 0.03166 seconds
Time Taken: 0.00227 seconds
End call of global.php: 0.033349990844727
Time Before: 0.03454 seconds
Time After: 0.03475 seconds
Time Before: 0.03792 seconds
Time After: 0.03938 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=23763'
Time Before: 0.05933 seconds
Time After: 0.05974 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.058286190032959 seconds with 9 queries, spending 0.010868072509766 doing MySQL queries and 0.047418117523193 doing PHP things.
