Time Before: 0.00145 seconds
Time After: 0.00192 seconds
Time Before: 0.00200 seconds
Time After: 0.00240 seconds
Time Before: 0.00261 seconds
Time After: 0.00273 seconds
Time Before: 0.00345 seconds
Time After: 0.00625 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00278 seconds
Time After: 0.00986 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01242 seconds
Time After: 0.01284 seconds
Time Before: 0.01426 seconds
Time After: 0.01553 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01164 seconds
Time After: 0.01577 seconds
Time Taken: 0.00414 seconds
Memory After: 2,261.836 KB
Time Before: 0.02117 seconds
Time After: 0.02135 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04292 seconds
Time After: 0.04420 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.047054052352905
Time Before: 0.04850 seconds
Time After: 0.04868 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.05076 seconds
Time After: 0.05224 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789093360, location = '/forums/private.php?do=newpm&explain=1&u=23773', badlocation = 1
Time Before: 0.06654 seconds
Time After: 0.06735 seconds
Time Taken: 0.00081 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.065505981445312 seconds with 9 queries, spending 0.0089304447174072 doing MySQL queries and 0.056575536727905 doing PHP things.
