Time Before: 0.02077 seconds
Time After: 0.02510 seconds
Time Taken: 0.00433 seconds
Time Before: 0.02520 seconds
Time After: 0.02562 seconds
Time Before: 0.02585 seconds
Time After: 0.02600 seconds
Time Before: 0.02679 seconds
Time After: 0.02893 seconds
Time Taken: 0.00214 seconds
Time Before: 0.02606 seconds
Time After: 0.03322 seconds
Time Taken: 0.00716 seconds
Time Before: 0.03971 seconds
Time After: 0.04015 seconds
Time Before: 0.04331 seconds
Time After: 0.04450 seconds
Time Before: 0.03893 seconds
Time After: 0.04476 seconds
Time Taken: 0.00583 seconds
Time Before: 0.07273 seconds
Time After: 0.07296 seconds
Memory Before: 3,438.367 KB
Memory After: 3,438.883 KB
Time Before: 0.08594 seconds
Time After: 0.08725 seconds
Time Taken: 0.00131 seconds
Time Before: 0.09430 seconds
Time After: 0.09444 seconds
Time Before: 0.09671 seconds
Time After: 0.09816 seconds
UPDATE session SET lastactivity = 1783333439, location = '/forums/private.php?do=newpm&explain=1&u=238' WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.11734 seconds
Time After: 0.11764 seconds
Memory Before: 4,911.117 KB
Memory After: 4,911.336 KB
