Time Before: 0.01896 seconds
Time After: 0.02489 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02500 seconds
Time After: 0.02559 seconds
Time Taken: 0.00059 seconds
Time Before: 0.02584 seconds
Time After: 0.02598 seconds
Time Before: 0.02680 seconds
Time After: 0.03445 seconds
Time Taken: 0.00766 seconds
Time Before: 0.02606 seconds
Time After: 0.03889 seconds
Time Taken: 0.01283 seconds
Time Before: 0.04460 seconds
Time After: 0.04492 seconds
Time Before: 0.04750 seconds
Time After: 0.04874 seconds
Time Before: 0.04371 seconds
Time After: 0.04901 seconds
Time Taken: 0.00530 seconds
Time Before: 0.07103 seconds
Time After: 0.07123 seconds
Time Before: 0.24048 seconds
Time After: 0.24172 seconds
Time Before: 0.25078 seconds
Time After: 0.25096 seconds
Time Before: 0.25436 seconds
Time After: 0.25585 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=23907', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.27541 seconds
Time After: 0.27573 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
