Time Before: 0.00136 seconds
Time After: 0.00212 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00220 seconds
Time After: 0.00258 seconds
Time Before: 0.00283 seconds
Time After: 0.00307 seconds
Time Before: 0.00380 seconds
Time After: 0.00697 seconds
Time Taken: 0.00317 seconds
Time Before: 0.00313 seconds
Time After: 0.01030 seconds
Time Taken: 0.00717 seconds
Time Before: 0.01202 seconds
Time After: 0.01240 seconds
Time Before: 0.01390 seconds
Time After: 0.01522 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01144 seconds
Time After: 0.01539 seconds
Time Taken: 0.00395 seconds
Time Before: 0.02029 seconds
Time After: 0.02046 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"12.53,\";s:9:\"lastcheck\";i:1788895973;}', 1)Time Before: 0.02571 seconds
Time After: 0.02621 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.02853 seconds
Time After: 0.02975 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.03312 seconds
Time After: 0.03328 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.03543 seconds
Time After: 0.03689 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1788895973, location = '/forums/private.php?do=newpm&explain=1&u=23952', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04985 seconds
Time After: 0.05010 seconds
Memory Before: 4,920.031 KB
Memory After: 4,920.242 KB
