Time Before: 0.00516 seconds
Time After: 0.00779 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00790 seconds
Time After: 0.00872 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00897 seconds
Time After: 0.00912 seconds
Time Before: 0.01021 seconds
Time After: 0.01271 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00920 seconds
Time After: 0.01687 seconds
Time Taken: 0.00766 seconds
Time Before: 0.01883 seconds
Time After: 0.01909 seconds
Time Before: 0.02187 seconds
Time After: 0.02400 seconds
Time Taken: 0.00213 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01820 seconds
Time After: 0.02429 seconds
Time Taken: 0.00609 seconds
Memory After: 2,261.836 KB
Time Before: 0.03205 seconds
Time After: 0.03218 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.03849 seconds
Time After: 0.03981 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.042435884475708
Time Before: 0.04557 seconds
Time After: 0.04573 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.04833 seconds
Time After: 0.04978 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788960558, location = '/forums/private.php?do=newpm&explain=1&u=24063'
Time Before: 0.06636 seconds
Time After: 0.06661 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.065232992172241 seconds with 9 queries, spending 0.0091731548309326 doing MySQL queries and 0.056059837341309 doing PHP things.
