Time Before: 0.02620 seconds
Time After: 0.03149 seconds
Time Taken: 0.00530 seconds
Time Before: 0.03157 seconds
Time After: 0.03192 seconds
Time Before: 0.03212 seconds
Time After: 0.03226 seconds
Time Before: 0.03296 seconds
Time After: 0.03494 seconds
Time Taken: 0.00199 seconds
Time Before: 0.03234 seconds
Time After: 0.03974 seconds
Time Taken: 0.00741 seconds
Time Before: 0.04913 seconds
Time After: 0.04954 seconds
Time Before: 0.05211 seconds
Time After: 0.05328 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04841 seconds
Time After: 0.05352 seconds
Time Taken: 0.00511 seconds
Time Before: 0.08965 seconds
Time After: 0.08978 seconds
Time Before: 0.11644 seconds
Time After: 0.11766 seconds
Time Before: 0.12995 seconds
Time After: 0.13009 seconds
Time Before: 0.13266 seconds
Time After: 0.13410 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=24103', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.15988 seconds
Time After: 0.16016 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
