Time Before: 0.00285 seconds
Time After: 0.00451 seconds
Time Taken: 0.00166 seconds
Time Before: 0.00466 seconds
Time After: 0.00533 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00558 seconds
Time After: 0.00573 seconds
Time Before: 0.00649 seconds
Time After: 0.00860 seconds
Time Taken: 0.00211 seconds
Time Before: 0.00578 seconds
Time After: 0.01198 seconds
Time Taken: 0.00620 seconds
Time Before: 0.01381 seconds
Time After: 0.01420 seconds
Time Before: 0.01564 seconds
Time After: 0.01728 seconds
Time Taken: 0.00163 seconds
Time Before: 0.01322 seconds
Time After: 0.01747 seconds
Time Taken: 0.00425 seconds
Time Before: 0.02289 seconds
Time After: 0.02311 seconds
Time Before: 0.02520 seconds
Time After: 0.02655 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.028237104415894
Time Before: 0.02989 seconds
Time After: 0.03004 seconds
Time Before: 0.03219 seconds
Time After: 0.03364 seconds
SET lastactivity = 1784774318, location = '/forums/private.php?do=newpm&explain=1&u=24168'
Time Before: 0.04853 seconds
Time After: 0.04886 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.047562122344971 seconds with 9 queries, spending 0.0084559917449951 doing MySQL queries and 0.039106130599976 doing PHP things.
