Time Before: 0.00146 seconds
Time After: 0.00206 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00217 seconds
Time After: 0.00277 seconds
Time Before: 0.00300 seconds
Time After: 0.00313 seconds
Time Before: 0.00389 seconds
Time After: 0.00708 seconds
Time Taken: 0.00320 seconds
Time Before: 0.00318 seconds
Time After: 0.01203 seconds
Time Taken: 0.00885 seconds
Time Before: 0.01443 seconds
Time After: 0.01489 seconds
Time Before: 0.01782 seconds
Time After: 0.01917 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01370 seconds
Time After: 0.01941 seconds
Time Taken: 0.00571 seconds
Time Before: 0.02581 seconds
Time After: 0.02597 seconds
Time Before: 0.02855 seconds
Time After: 0.02983 seconds
End call of global.php: 0.032428026199341
Time Before: 0.03387 seconds
Time After: 0.03408 seconds
Time Before: 0.03615 seconds
Time After: 0.03758 seconds
SET lastactivity = 1789142981, location = '/forums/private.php?do=newpm&explain=1&u=24247'
Time Before: 0.04998 seconds
Time After: 0.05041 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049079895019531 seconds with 9 queries, spending 0.0092387199401855 doing MySQL queries and 0.039841175079346 doing PHP things.
