Time Before: 0.01044 seconds
Time After: 0.01369 seconds
Time Taken: 0.00325 seconds
Time Before: 0.01379 seconds
Time After: 0.01424 seconds
Time Before: 0.01451 seconds
Time After: 0.01468 seconds
Time Before: 0.01544 seconds
Time After: 0.01795 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01474 seconds
Time After: 0.02236 seconds
Time Taken: 0.00762 seconds
Time Before: 0.02673 seconds
Time After: 0.02715 seconds
Time Before: 0.02951 seconds
Time After: 0.03082 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02598 seconds
Time After: 0.03106 seconds
Time Taken: 0.00508 seconds
Time Before: 0.04700 seconds
Time After: 0.04723 seconds
Time Before: 0.05487 seconds
Time After: 0.05617 seconds
Time Before: 0.06164 seconds
Time After: 0.06181 seconds
Time Before: 0.06449 seconds
Time After: 0.06597 seconds
UPDATE session SET lastactivity = 1772656356, location = '/forums/private.php?do=newpm&explain=1&u=24258' WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.08461 seconds
Time After: 0.08488 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
