Time Before: 0.00150 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00243 seconds
Time Before: 0.00264 seconds
Time After: 0.00277 seconds
Time Before: 0.00342 seconds
Time After: 0.00556 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00282 seconds
Time After: 0.00994 seconds
Time Taken: 0.00712 seconds
Time Before: 0.01201 seconds
Time After: 0.01241 seconds
Time Before: 0.01507 seconds
Time After: 0.01638 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01144 seconds
Time After: 0.01665 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02431 seconds
Time After: 0.02446 seconds
Time Before: 0.02629 seconds
Time After: 0.02764 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03191 seconds
Time After: 0.03211 seconds
Time Before: 0.03540 seconds
Time After: 0.03690 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=24273', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05333 seconds
Time After: 0.05368 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
