Time Before: 0.00196 seconds
Time After: 0.00251 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00261 seconds
Time After: 0.00306 seconds
Time Before: 0.00326 seconds
Time After: 0.00338 seconds
Time Before: 0.00401 seconds
Time After: 0.00652 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00343 seconds
Time After: 0.00989 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01163 seconds
Time After: 0.01213 seconds
Time Before: 0.01482 seconds
Time After: 0.01603 seconds
Time Before: 0.01102 seconds
Time After: 0.01621 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02145 seconds
Time After: 0.02162 seconds
Time Before: 0.02375 seconds
Time After: 0.02497 seconds
Time Before: 0.02784 seconds
Time After: 0.02808 seconds
Time Before: 0.03016 seconds
Time After: 0.03171 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=24319' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04426 seconds
Time After: 0.04449 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
