Time Before: 0.02150 seconds
Time After: 0.02639 seconds
Time Taken: 0.00489 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02647 seconds
Time After: 0.02686 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02707 seconds
Time After: 0.02720 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02796 seconds
Time After: 0.03031 seconds
Time Taken: 0.00236 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02726 seconds
Time After: 0.03456 seconds
Time Taken: 0.00730 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.04214 seconds
Time After: 0.04234 seconds
Time Before: 0.04558 seconds
Time After: 0.04676 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04145 seconds
Time After: 0.04698 seconds
Time Taken: 0.00553 seconds
Memory After: 2,261.703 KB
Time Before: 0.08068 seconds
Time After: 0.08080 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.10114 seconds
Time After: 0.10238 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.10446500778198
Time Before: 0.11080 seconds
Time After: 0.11098 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.11354 seconds
Time After: 0.11499 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=24414', badlocation = 1
Time Before: 0.13410 seconds
Time After: 0.13441 seconds
Memory Before: 4,295.766 KB
Memory After: 4,295.992 KB
Page generated in 0.13303804397583 seconds with 9 queries, spending 0.0075757503509521 doing MySQL queries and 0.12546229362488 doing PHP things.
