Time Before: 0.01346 seconds
Time After: 0.01856 seconds
Time Taken: 0.00510 seconds
Time Before: 0.01868 seconds
Time After: 0.01912 seconds
Time Before: 0.01936 seconds
Time After: 0.01951 seconds
Time Before: 0.02034 seconds
Time After: 0.02265 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01959 seconds
Time After: 0.02693 seconds
Time Taken: 0.00734 seconds
Time Before: 0.03168 seconds
Time After: 0.03192 seconds
Time Before: 0.03507 seconds
Time After: 0.03635 seconds
Time Before: 0.03090 seconds
Time After: 0.03657 seconds
Time Taken: 0.00567 seconds
Time Before: 0.06345 seconds
Time After: 0.06360 seconds
Time Before: 1.28276 seconds
Time After: 1.28465 seconds
Time Taken: 0.00189 seconds
Time Before: 1.29075 seconds
Time After: 1.29093 seconds
Time Before: 1.29349 seconds
Time After: 1.29506 seconds
Time Taken: 0.00156 seconds
UPDATE session SET lastactivity = 1784785703, location = '/forums/private.php?do=newpm&explain=1&u=24493' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 1.31166 seconds
Time After: 1.31226 seconds
Time Taken: 0.00060 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
