Time Before: 0.02511 seconds
Time After: 0.03035 seconds
Time Taken: 0.00524 seconds
Time Before: 0.03043 seconds
Time After: 0.03085 seconds
Time Before: 0.03111 seconds
Time After: 0.03124 seconds
Time Before: 0.03213 seconds
Time After: 0.03434 seconds
Time Taken: 0.00221 seconds
Time Before: 0.03132 seconds
Time After: 0.03839 seconds
Time Taken: 0.00708 seconds
Time Before: 0.04533 seconds
Time After: 0.04571 seconds
Time Before: 0.04812 seconds
Time After: 0.04933 seconds
Time Before: 0.04470 seconds
Time After: 0.04952 seconds
Time Taken: 0.00482 seconds
Time Before: 0.09096 seconds
Time After: 0.09131 seconds
Time Before: 0.11060 seconds
Time After: 0.11270 seconds
Time Taken: 0.00210 seconds
End call of global.php: 0.11528515815735
Time Before: 0.12784 seconds
Time After: 0.12801 seconds
Time Before: 0.13060 seconds
Time After: 0.13207 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=24564'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.15000 seconds
Time After: 0.15104 seconds
Time Taken: 0.00104 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.14896702766418 seconds with 9 queries, spending 0.0094828605651855 doing MySQL queries and 0.139484167099 doing PHP things.
