Time Before: 0.00184 seconds
Time After: 0.00240 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00253 seconds
Time After: 0.00300 seconds
Time Before: 0.00325 seconds
Time After: 0.00340 seconds
Time Before: 0.00428 seconds
Time After: 0.00687 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00348 seconds
Time After: 0.01043 seconds
Time Taken: 0.00695 seconds
Time Before: 0.01233 seconds
Time After: 0.01279 seconds
Time Before: 0.01530 seconds
Time After: 0.01651 seconds
Time Before: 0.01165 seconds
Time After: 0.01668 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02201 seconds
Time After: 0.02216 seconds
Time Before: 0.02402 seconds
Time After: 0.02526 seconds
End call of global.php: 0.026870012283325
Time Before: 0.02832 seconds
Time After: 0.02848 seconds
Time Before: 0.03120 seconds
Time After: 0.03262 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=24565'
Time Before: 0.04655 seconds
Time After: 0.04702 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045521020889282 seconds with 9 queries, spending 0.0083184242248535 doing MySQL queries and 0.037202596664429 doing PHP things.
