Time Before: 0.00171 seconds
Time After: 0.00216 seconds
Time Before: 0.00223 seconds
Time After: 0.00270 seconds
Time Before: 0.00292 seconds
Time After: 0.00303 seconds
Time Before: 0.00393 seconds
Time After: 0.00635 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00311 seconds
Time After: 0.01129 seconds
Time Taken: 0.00818 seconds
Time Before: 0.01317 seconds
Time After: 0.01356 seconds
Time Before: 0.01601 seconds
Time After: 0.01731 seconds
Time Before: 0.01258 seconds
Time After: 0.01755 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02401 seconds
Time After: 0.02425 seconds
Time Before: 0.02655 seconds
Time After: 0.02782 seconds
End call of global.php: 0.030150890350342
Time Before: 0.03153 seconds
Time After: 0.03172 seconds
Time Before: 0.03450 seconds
Time After: 0.03629 seconds
Time Taken: 0.00179 seconds
SET lastactivity = 1776464933, location = '/forums/private.php?do=newpm&explain=1&u=24721'
Time Before: 0.05307 seconds
Time After: 0.05354 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.052031993865967 seconds with 9 queries, spending 0.0086565017700195 doing MySQL queries and 0.043375492095947 doing PHP things.
