Time Before: 0.00132 seconds
Time After: 0.00224 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00245 seconds
Time After: 0.00294 seconds
Time Before: 0.00324 seconds
Time After: 0.00346 seconds
Time Before: 0.00447 seconds
Time After: 0.00767 seconds
Time Taken: 0.00320 seconds
Time Before: 0.00354 seconds
Time After: 0.01308 seconds
Time Taken: 0.00954 seconds
Time Before: 0.01598 seconds
Time After: 0.01642 seconds
Time Before: 0.01939 seconds
Time After: 0.02062 seconds
Time Before: 0.01481 seconds
Time After: 0.02079 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02651 seconds
Time After: 0.02666 seconds
Time Before: 0.02871 seconds
Time After: 0.03002 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.031715869903564
Time Before: 0.03329 seconds
Time After: 0.03344 seconds
Time Before: 0.03550 seconds
Time After: 0.03698 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=24723', badlocation = 1
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.04934 seconds
Time After: 0.04961 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.048441886901855 seconds with 9 queries, spending 0.0089457035064697 doing MySQL queries and 0.039496183395386 doing PHP things.
