Time Before: 0.00142 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00251 seconds
Time Before: 0.00274 seconds
Time After: 0.00293 seconds
Time Before: 0.00379 seconds
Time After: 0.00651 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00301 seconds
Time After: 0.01013 seconds
Time Taken: 0.00712 seconds
Time Before: 0.01203 seconds
Time After: 0.01241 seconds
Time Before: 0.01547 seconds
Time After: 0.01673 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01141 seconds
Time After: 0.01697 seconds
Time Taken: 0.00557 seconds
Memory After: 2,261.836 KB
Time Before: 0.02213 seconds
Time After: 0.02227 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02457 seconds
Time After: 0.02580 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.028353929519653
Time Before: 0.02968 seconds
Time After: 0.02986 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03280 seconds
Time After: 0.03427 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789123767, location = '/forums/private.php?do=newpm&explain=1&u=24811', badlocation = 1
Time Before: 0.04954 seconds
Time After: 0.04982 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.048493146896362 seconds with 9 queries, spending 0.0083599090576172 doing MySQL queries and 0.040133237838745 doing PHP things.
