Time Before: 0.00171 seconds
Time After: 0.00234 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00244 seconds
Time After: 0.00286 seconds
Time Before: 0.00313 seconds
Time After: 0.00325 seconds
Time Before: 0.00405 seconds
Time After: 0.00618 seconds
Time Taken: 0.00213 seconds
Time Before: 0.00332 seconds
Time After: 0.01097 seconds
Time Taken: 0.00765 seconds
Time Before: 0.01341 seconds
Time After: 0.01383 seconds
Time Before: 0.01638 seconds
Time After: 0.01758 seconds
Time Before: 0.01276 seconds
Time After: 0.01778 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02405 seconds
Time After: 0.02424 seconds
Time Before: 0.02646 seconds
Time After: 0.02773 seconds
Time Before: 0.03163 seconds
Time After: 0.03182 seconds
Time Before: 0.03462 seconds
Time After: 0.03606 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=24870', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04930 seconds
Time After: 0.04964 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
