Time Before: 0.00137 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00227 seconds
Time Before: 0.00247 seconds
Time After: 0.00265 seconds
Time Before: 0.00331 seconds
Time After: 0.00569 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00270 seconds
Time After: 0.00999 seconds
Time Taken: 0.00729 seconds
Time Before: 0.01187 seconds
Time After: 0.01229 seconds
Time Before: 0.01518 seconds
Time After: 0.01639 seconds
Time Before: 0.01123 seconds
Time After: 0.01657 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02174 seconds
Time After: 0.02192 seconds
Time Before: 0.02423 seconds
Time After: 0.02562 seconds
Time Taken: 0.00138 seconds
Time Before: 0.02960 seconds
Time After: 0.02974 seconds
Time Before: 0.03241 seconds
Time After: 0.03383 seconds
UPDATE session SET lastactivity = 1772831834, location = '/forums/private.php?do=newpm&explain=1&u=2493', badlocation = 1 WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.04635 seconds
Time After: 0.04668 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
