Time Before: 0.00157 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00254 seconds
Time Before: 0.00279 seconds
Time After: 0.00293 seconds
Time Before: 0.00385 seconds
Time After: 0.00634 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00300 seconds
Time After: 0.00971 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01146 seconds
Time After: 0.01246 seconds
Time Taken: 0.00100 seconds
Time Before: 0.01588 seconds
Time After: 0.01713 seconds
Time Before: 0.01085 seconds
Time After: 0.01737 seconds
Time Taken: 0.00653 seconds
Time Before: 0.02411 seconds
Time After: 0.02425 seconds
Time Before: 0.02680 seconds
Time After: 0.02806 seconds
Time Before: 0.03146 seconds
Time After: 0.03161 seconds
Time Before: 0.03407 seconds
Time After: 0.03554 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=25038', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05341 seconds
Time After: 0.05372 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
