Time Before: 0.00431 seconds
Time After: 0.00754 seconds
Time Taken: 0.00322 seconds
Time Before: 0.00761 seconds
Time After: 0.00799 seconds
Time Before: 0.00820 seconds
Time After: 0.00830 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00906 seconds
Time After: 0.01266 seconds
Time Taken: 0.00360 seconds
Time Before: 0.00835 seconds
Time After: 0.01811 seconds
Time Taken: 0.00976 seconds
Time Before: 0.02356 seconds
Time After: 0.02394 seconds
Time Before: 0.02724 seconds
Time After: 0.02843 seconds
Time Before: 0.02211 seconds
Time After: 0.02870 seconds
Time Taken: 0.00659 seconds
Time Before: 0.04128 seconds
Time After: 0.04149 seconds
Time Before: 0.05014 seconds
Time After: 0.05140 seconds
End call of global.php: 0.053777933120728
Time Before: 0.05802 seconds
Time After: 0.05818 seconds
Time Before: 0.06051 seconds
Time After: 0.06250 seconds
Time Taken: 0.00199 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=2508', badlocation = 1
Time Before: 0.07909 seconds
Time After: 0.07950 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
Page generated in 0.077992916107178 seconds with 9 queries, spending 0.0096938610076904 doing MySQL queries and 0.068299055099487 doing PHP things.
