Time Before: 0.00725 seconds
Time After: 0.00906 seconds
Time Taken: 0.00182 seconds
Time Before: 0.00916 seconds
Time After: 0.00952 seconds
Time Before: 0.00975 seconds
Time After: 0.00990 seconds
Time Before: 0.01081 seconds
Time After: 0.01407 seconds
Time Taken: 0.00327 seconds
Time Before: 0.00998 seconds
Time After: 0.01972 seconds
Time Taken: 0.00973 seconds
Time Before: 0.02406 seconds
Time After: 0.02441 seconds
Time Before: 0.02696 seconds
Time After: 0.02826 seconds
Time Before: 0.02328 seconds
Time After: 0.02851 seconds
Time Taken: 0.00523 seconds
Time Before: 0.04595 seconds
Time After: 0.04609 seconds
Time Before: 0.05511 seconds
Time After: 0.05649 seconds
Time Taken: 0.00138 seconds
Time Before: 0.06355 seconds
Time After: 0.06370 seconds
Time Before: 0.06677 seconds
Time After: 0.06819 seconds
UPDATE session SET lastactivity = 1785356630, location = '/forums/private.php?do=newpm&explain=1&u=25090', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08319 seconds
Time After: 0.08614 seconds
Time Taken: 0.00295 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
