Time Before: 0.01835 seconds
Time After: 0.02431 seconds
Time Taken: 0.00596 seconds
Time Before: 0.02441 seconds
Time After: 0.02487 seconds
Time Before: 0.02510 seconds
Time After: 0.02527 seconds
Time Before: 0.02605 seconds
Time After: 0.02886 seconds
Time Taken: 0.00281 seconds
Time Before: 0.02534 seconds
Time After: 0.03292 seconds
Time Taken: 0.00758 seconds
Time Before: 0.04238 seconds
Time After: 0.04258 seconds
Time Before: 0.04491 seconds
Time After: 0.04614 seconds
Time Before: 0.04176 seconds
Time After: 0.04634 seconds
Time Taken: 0.00458 seconds
Time Before: 0.08782 seconds
Time After: 0.08816 seconds
Time Before: 0.10635 seconds
Time After: 0.10760 seconds
End call of global.php: 0.10962700843811
Time Before: 0.11751 seconds
Time After: 0.11782 seconds
Time Before: 0.12081 seconds
Time After: 0.12230 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=25114'
Time Before: 0.14478 seconds
Time After: 0.14509 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.14336585998535 seconds with 9 queries, spending 0.0085909366607666 doing MySQL queries and 0.13477492332458 doing PHP things.
