Time Before: 0.01466 seconds
Time After: 0.01675 seconds
Time Taken: 0.00208 seconds
Time Before: 0.01689 seconds
Time After: 0.01732 seconds
Time Before: 0.01757 seconds
Time After: 0.01770 seconds
Time Before: 0.01860 seconds
Time After: 0.02068 seconds
Time Before: 0.01779 seconds
Time After: 0.02499 seconds
Time Taken: 0.00720 seconds
Time Before: 0.02996 seconds
Time After: 0.03023 seconds
Time Before: 0.03368 seconds
Time After: 0.03491 seconds
Time Before: 0.02925 seconds
Time After: 0.03510 seconds
Time Taken: 0.00585 seconds
Time Before: 0.04664 seconds
Time After: 0.04675 seconds
Time Before: 1.97526 seconds
Time After: 1.97699 seconds
Time Taken: 0.00173 seconds
Time Before: 1.98140 seconds
Time After: 1.98158 seconds
Time Before: 1.98394 seconds
Time After: 1.98597 seconds
Time Taken: 0.00203 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=25177' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 2.00421 seconds
Time After: 2.00445 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
