Time Before: 0.02370 seconds
Time After: 0.03277 seconds
Time Taken: 0.00907 seconds
Time Before: 0.03287 seconds
Time After: 0.03340 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03365 seconds
Time After: 0.03381 seconds
Time Before: 0.03462 seconds
Time After: 0.03712 seconds
Time Taken: 0.00250 seconds
Time Before: 0.03387 seconds
Time After: 0.04127 seconds
Time Taken: 0.00740 seconds
Time Before: 0.05135 seconds
Time After: 0.05178 seconds
Time Before: 0.05427 seconds
Time After: 0.05543 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05073 seconds
Time After: 0.05565 seconds
Time Taken: 0.00491 seconds
Time Before: 0.09094 seconds
Time After: 0.09107 seconds
Time Before: 0.11207 seconds
Time After: 0.11337 seconds
End call of global.php: 0.11548089981079
Time Before: 0.12650 seconds
Time After: 0.12664 seconds
Time Before: 0.12902 seconds
Time After: 0.13051 seconds
SET lastactivity = 1782850395, location = '/forums/private.php?do=newpm&explain=1&u=25212'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.14991 seconds
Time After: 0.15021 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.14880394935608 seconds with 9 queries, spending 0.008129358291626 doing MySQL queries and 0.14067459106445 doing PHP things.
