Time Before: 0.00164 seconds
Time After: 0.00210 seconds
Time Before: 0.00217 seconds
Time After: 0.00260 seconds
Time Before: 0.00289 seconds
Time After: 0.00304 seconds
Time Before: 0.00387 seconds
Time After: 0.00675 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00311 seconds
Time After: 0.01134 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01325 seconds
Time After: 0.01369 seconds
Time Before: 0.01654 seconds
Time After: 0.01783 seconds
Time Before: 0.01249 seconds
Time After: 0.01811 seconds
Time Taken: 0.00562 seconds
Time Before: 0.02565 seconds
Time After: 0.02584 seconds
Time Before: 0.02846 seconds
Time After: 0.03037 seconds
Time Taken: 0.00190 seconds
Time Before: 0.03460 seconds
Time After: 0.03475 seconds
Time Before: 0.03812 seconds
Time After: 0.03962 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1788909208, location = '/forums/private.php?do=newpm&explain=1&u=25318', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05370 seconds
Time After: 0.05405 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
