Time Before: 0.01072 seconds
Time After: 0.01478 seconds
Time Taken: 0.00405 seconds
Time Before: 0.01489 seconds
Time After: 0.01534 seconds
Time Before: 0.01558 seconds
Time After: 0.01572 seconds
Time Before: 0.01655 seconds
Time After: 0.01952 seconds
Time Taken: 0.00296 seconds
Time Before: 0.01581 seconds
Time After: 0.02334 seconds
Time Taken: 0.00754 seconds
Time Before: 0.02963 seconds
Time After: 0.02998 seconds
Time Before: 0.03259 seconds
Time After: 0.03377 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02883 seconds
Time After: 0.03394 seconds
Time Taken: 0.00511 seconds
Time Before: 0.05595 seconds
Time After: 0.05609 seconds
Time Before: 0.06986 seconds
Time After: 0.07115 seconds
End call of global.php: 0.073280096054077
Time Before: 0.07840 seconds
Time After: 0.07858 seconds
Time Before: 0.08152 seconds
Time After: 0.08300 seconds
SET lastactivity = 1783201257, location = '/forums/private.php?do=newpm&explain=1&u=25361', badlocation = 1
Time Before: 0.10120 seconds
Time After: 0.10147 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
Page generated in 0.10010004043579 seconds with 9 queries, spending 0.0084660053253174 doing MySQL queries and 0.091634035110474 doing PHP things.
