Time Before: 0.01396 seconds
Time After: 0.01898 seconds
Time Taken: 0.00502 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01908 seconds
Time After: 0.01956 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01981 seconds
Time After: 0.01993 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02069 seconds
Time After: 0.02326 seconds
Time Taken: 0.00258 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02000 seconds
Time After: 0.02712 seconds
Time Taken: 0.00712 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.03385 seconds
Time After: 0.03427 seconds
Time Before: 0.03572 seconds
Time After: 0.03694 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03321 seconds
Time After: 0.03722 seconds
Time Taken: 0.00401 seconds
Memory After: 2,261.820 KB
Time Before: 0.06701 seconds
Time After: 0.06719 seconds
Memory Before: 2,815.414 KB
Memory After: 2,815.930 KB
Time Before: 0.08117 seconds
Time After: 0.08244 seconds
Memory Before: 2,903.719 KB
Memory After: 2,904.313 KB
End call of global.php: 0.084520816802979
Time Before: 0.09006 seconds
Time After: 0.09025 seconds
Memory Before: 3,540.484 KB
Memory After: 3,540.914 KB
Time Before: 0.09356 seconds
Time After: 0.09508 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,822.031 KB
Memory After: 3,823.703 KB
Memory Used: 1.672 KB
SET lastactivity = 1785368906, location = '/forums/private.php?do=newpm&explain=1&u=25480'
Time Before: 0.11451 seconds
Time After: 0.11482 seconds
Memory Before: 4,295.875 KB
Memory After: 4,296.102 KB
Page generated in 0.11358380317688 seconds with 9 queries, spending 0.0082950592041016 doing MySQL queries and 0.10528874397278 doing PHP things.
