Time Before: 0.03134 seconds
Time After: 0.03772 seconds
Time Taken: 0.00638 seconds
Memory Before: 532.305 KB
Memory After: 557.422 KB
Time Before: 0.03783 seconds
Time After: 0.03831 seconds
Memory Before: 557.359 KB
Memory After: 558.367 KB
Time Before: 0.03855 seconds
Time After: 0.03873 seconds
Memory Before: 558.922 KB
Memory After: 559.445 KB
Time Before: 0.03964 seconds
Time After: 0.04205 seconds
Time Taken: 0.00241 seconds
Memory Before: 562.047 KB
Memory After: 562.969 KB
Time Before: 0.03880 seconds
Time After: 0.04596 seconds
Time Taken: 0.00715 seconds
Memory Before: 558.695 KB
Memory After: 1,639.742 KB
Memory Used: 1,081.047 KB
Time Before: 0.05548 seconds
Time After: 0.05596 seconds
Memory Before: 2,134.648 KB
Memory After: 2,135.266 KB
Time Before: 0.05853 seconds
Time After: 0.05971 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,146.828 KB
Memory After: 2,146.688 KB
Time Before: 0.05474 seconds
Time After: 0.05991 seconds
Time Taken: 0.00517 seconds
Memory Before: 2,126.828 KB
Memory After: 2,260.039 KB
Memory Used: 133.211 KB
Time Before: 0.09948 seconds
Time After: 0.09964 seconds
Memory Before: 2,813.594 KB
Memory After: 2,814.109 KB
Time Before: 0.12514 seconds
Time After: 0.12639 seconds
Memory Before: 2,901.883 KB
Memory After: 2,902.477 KB
Time Before: 0.14170 seconds
Time After: 0.14182 seconds
Memory Before: 3,538.609 KB
Memory After: 3,539.039 KB
Time Before: 0.14418 seconds
Time After: 0.14564 seconds
Memory Before: 3,820.141 KB
Memory After: 3,821.828 KB
UPDATE session SET lastactivity = 1789134774, location = '/forums/private.php?do=newpm&explain=1&u=256', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.16400 seconds
Time After: 0.16456 seconds
Time Taken: 0.00056 seconds
Memory Before: 4,298.711 KB
Memory After: 4,298.914 KB
Memory Used: 0.203 KB
