Time Before: 0.00264 seconds
Time After: 0.00342 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00352 seconds
Time After: 0.00400 seconds
Time Before: 0.00433 seconds
Time After: 0.00448 seconds
Time Before: 0.00545 seconds
Time After: 0.00790 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00453 seconds
Time After: 0.01139 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01312 seconds
Time After: 0.01353 seconds
Time Before: 0.01604 seconds
Time After: 0.01730 seconds
Time Before: 0.01254 seconds
Time After: 0.01748 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02289 seconds
Time After: 0.02303 seconds
Time Before: 0.02509 seconds
Time After: 0.02634 seconds
Time Before: 0.02937 seconds
Time After: 0.02952 seconds
Time Before: 0.03151 seconds
Time After: 0.03302 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=25629', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04532 seconds
Time After: 0.04561 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
