Time Before: 0.01265 seconds
Time After: 0.01535 seconds
Time Taken: 0.00270 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01546 seconds
Time After: 0.01587 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01612 seconds
Time After: 0.01625 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01695 seconds
Time After: 0.01953 seconds
Time Taken: 0.00258 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01630 seconds
Time After: 0.02355 seconds
Time Taken: 0.00725 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02792 seconds
Time After: 0.02829 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03081 seconds
Time After: 0.03204 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.02726 seconds
Time After: 0.03226 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.05230 seconds
Time After: 0.05247 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.18291 seconds
Time After: 0.18431 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.20253 seconds
Time After: 0.20273 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.20672 seconds
Time After: 0.20814 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1773159833, location = '/forums/private.php?do=newpm&explain=1&u=25777', badlocation = 1 WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.23253 seconds
Time After: 0.23281 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
