Time Before: 0.00176 seconds
Time After: 0.00254 seconds
Time Taken: 0.00078 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00266 seconds
Time After: 0.00323 seconds
Time Taken: 0.00057 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00346 seconds
Time After: 0.00364 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00438 seconds
Time After: 0.00764 seconds
Time Taken: 0.00326 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00369 seconds
Time After: 0.01102 seconds
Time Taken: 0.00733 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01275 seconds
Time After: 0.01318 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01574 seconds
Time After: 0.01716 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01216 seconds
Time After: 0.01735 seconds
Time Taken: 0.00520 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.02248 seconds
Time After: 0.02263 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.02491 seconds
Time After: 0.02622 seconds
Time Taken: 0.00131 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.027845144271851
Time Before: 0.02901 seconds
Time After: 0.02913 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.03108 seconds
Time After: 0.03250 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1782850897, location = '/forums/private.php?do=newpm&explain=1&u=25782'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.04473 seconds
Time After: 0.04510 seconds
Memory Before: 4,922.117 KB
Memory After: 4,922.320 KB
Memory Used: 0.203 KB
Page generated in 0.043877124786377 seconds with 9 queries, spending 0.0092298984527588 doing MySQL queries and 0.034647226333618 doing PHP things.
