Time Before: 0.01123 seconds
Time After: 0.01655 seconds
Time Taken: 0.00532 seconds
Time Before: 0.01664 seconds
Time After: 0.01704 seconds
Time Before: 0.01724 seconds
Time After: 0.01734 seconds
Time Taken: 0.00010 seconds
Time Before: 0.01804 seconds
Time After: 0.02038 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01741 seconds
Time After: 0.02431 seconds
Time Taken: 0.00690 seconds
Time Before: 0.03382 seconds
Time After: 0.03421 seconds
Time Before: 0.03577 seconds
Time After: 0.03696 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03313 seconds
Time After: 0.03718 seconds
Time Taken: 0.00405 seconds
Memory After: 2,261.836 KB
Time Before: 0.06333 seconds
Time After: 0.06350 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.07600 seconds
Time After: 0.07723 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.079536914825439
Time Before: 0.08497 seconds
Time After: 0.08515 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08808 seconds
Time After: 0.08965 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789115396, location = '/forums/private.php?do=newpm&explain=1&u=25794'
Time Before: 0.10843 seconds
Time After: 0.10884 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.10732007026672 seconds with 9 queries, spending 0.0079848766326904 doing MySQL queries and 0.099335193634033 doing PHP things.
