Time Before: 0.02299 seconds
Time After: 0.02942 seconds
Time Taken: 0.00642 seconds
Time Before: 0.02953 seconds
Time After: 0.03074 seconds
Time Before: 0.03106 seconds
Time After: 0.03122 seconds
Time Before: 0.03211 seconds
Time After: 0.03427 seconds
Time Taken: 0.00217 seconds
Time Before: 0.03130 seconds
Time After: 0.03771 seconds
Time Before: 0.04587 seconds
Time After: 0.04625 seconds
Time Before: 0.04773 seconds
Time After: 0.04911 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04522 seconds
Time After: 0.04934 seconds
Time Taken: 0.00411 seconds
Memory After: 2,261.836 KB
Time Before: 0.07621 seconds
Time After: 0.07640 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09472 seconds
Time After: 0.09602 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10610 seconds
Time After: 0.10626 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10840 seconds
Time After: 0.10984 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789077486, location = '/forums/private.php?do=newpm&explain=1&u=25845', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12632 seconds
Time After: 0.12665 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
