Time Before: 0.00199 seconds
Time After: 0.00255 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00262 seconds
Time After: 0.00303 seconds
Time Before: 0.00327 seconds
Time After: 0.00340 seconds
Time Before: 0.00416 seconds
Time After: 0.00687 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00348 seconds
Time After: 0.01030 seconds
Time Taken: 0.00682 seconds
Time Before: 0.01220 seconds
Time After: 0.01264 seconds
Time Before: 0.01620 seconds
Time After: 0.01851 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01147 seconds
Time After: 0.01868 seconds
Time Taken: 0.00722 seconds
Time Before: 0.02605 seconds
Time After: 0.02619 seconds
Time Before: 0.02804 seconds
Time After: 0.03045 seconds
Time Taken: 0.00241 seconds
Time Before: 0.03354 seconds
Time After: 0.03367 seconds
Time Before: 0.03592 seconds
Time After: 0.03821 seconds
Time Taken: 0.00229 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=25851' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05071 seconds
Time After: 0.05113 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
