Time Before: 0.01382 seconds
Time After: 0.01931 seconds
Time Taken: 0.00549 seconds
Time Before: 0.01943 seconds
Time After: 0.02062 seconds
Time Before: 0.02086 seconds
Time After: 0.02105 seconds
Time Before: 0.02218 seconds
Time After: 0.02545 seconds
Time Taken: 0.00326 seconds
Time Before: 0.02112 seconds
Time After: 0.02958 seconds
Time Taken: 0.00847 seconds
Time Before: 0.04131 seconds
Time After: 0.04222 seconds
Time Taken: 0.00091 seconds
Time Before: 0.04559 seconds
Time After: 0.04678 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04014 seconds
Time After: 0.04704 seconds
Time Taken: 0.00690 seconds
Memory After: 2,261.719 KB
Time Before: 0.06957 seconds
Time After: 0.06972 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08851 seconds
Time After: 0.08977 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.092136144638062
Time Before: 0.10082 seconds
Time After: 0.10097 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10337 seconds
Time After: 0.10494 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=25873'
Time Before: 0.12480 seconds
Time After: 0.12509 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.12385702133179 seconds with 9 queries, spending 0.010177135467529 doing MySQL queries and 0.11367988586426 doing PHP things.
