Time Before: 0.00151 seconds
Time After: 0.00202 seconds
Time Before: 0.00210 seconds
Time After: 0.00249 seconds
Time Before: 0.00273 seconds
Time After: 0.00288 seconds
Time Before: 0.00353 seconds
Time After: 0.00602 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00293 seconds
Time After: 0.00963 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01188 seconds
Time After: 0.01232 seconds
Time Before: 0.01469 seconds
Time After: 0.01615 seconds
Time Before: 0.01124 seconds
Time After: 0.01632 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02161 seconds
Time After: 0.02175 seconds
Time Before: 0.02386 seconds
Time After: 0.02512 seconds
Time Before: 0.02793 seconds
Time After: 0.02811 seconds
Time Before: 0.03006 seconds
Time After: 0.03151 seconds
UPDATE session SET lastactivity = 1783007155, location = '/forums/private.php?do=newpm&explain=1&u=2592' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04855 seconds
Time After: 0.04888 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
