Time Before: 0.01838 seconds
Time After: 0.02332 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02339 seconds
Time After: 0.02378 seconds
Time Before: 0.02398 seconds
Time After: 0.02411 seconds
Time Before: 0.02488 seconds
Time After: 0.02706 seconds
Time Taken: 0.00217 seconds
Time Before: 0.02416 seconds
Time After: 0.03110 seconds
Time Taken: 0.00693 seconds
Time Before: 0.04150 seconds
Time After: 0.04202 seconds
Time Before: 0.04521 seconds
Time After: 0.04645 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04086 seconds
Time After: 0.04666 seconds
Time Taken: 0.00581 seconds
Memory After: 2,261.719 KB
Time Before: 0.06652 seconds
Time After: 0.06666 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08770 seconds
Time After: 0.08894 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.091273069381714
Time Before: 0.09869 seconds
Time After: 0.09889 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10245 seconds
Time After: 0.10389 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=25970'
Time Before: 0.12396 seconds
Time After: 0.12425 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.12288904190063 seconds with 9 queries, spending 0.0077395439147949 doing MySQL queries and 0.11514949798584 doing PHP things.
