Time Before: 0.00563 seconds
Time After: 0.00766 seconds
Time Taken: 0.00204 seconds
Time Before: 0.00777 seconds
Time After: 0.00842 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00865 seconds
Time After: 0.00877 seconds
Time Before: 0.00950 seconds
Time After: 0.01225 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00882 seconds
Time After: 0.01567 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01864 seconds
Time After: 0.01905 seconds
Time Before: 0.02046 seconds
Time After: 0.02174 seconds
Time Before: 0.01802 seconds
Time After: 0.02217 seconds
Time Taken: 0.00415 seconds
Time Before: 0.03407 seconds
Time After: 0.03421 seconds
Time Before: 0.03763 seconds
Time After: 0.03891 seconds
End call of global.php: 0.041282892227173
Time Before: 0.04433 seconds
Time After: 0.04447 seconds
Time Before: 0.04741 seconds
Time After: 0.04886 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=26044', badlocation = 1
Time Before: 0.06374 seconds
Time After: 0.06408 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.062839031219482 seconds with 9 queries, spending 0.0085780620574951 doing MySQL queries and 0.054260969161987 doing PHP things.
