Time Before: 0.00232 seconds
Time After: 0.00309 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00316 seconds
Time After: 0.00359 seconds
Time Before: 0.00377 seconds
Time After: 0.00394 seconds
Time Before: 0.00468 seconds
Time After: 0.00675 seconds
Time Taken: 0.00207 seconds
Time Before: 0.00398 seconds
Time After: 0.01055 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01298 seconds
Time After: 0.01341 seconds
Time Before: 0.01655 seconds
Time After: 0.01801 seconds
Time Before: 0.01235 seconds
Time After: 0.01820 seconds
Time Taken: 0.00585 seconds
Time Before: 0.02330 seconds
Time After: 0.02346 seconds
Time Before: 0.02574 seconds
Time After: 0.02714 seconds
Time Taken: 0.00140 seconds
End call of global.php: 0.030026912689209
Time Before: 0.03250 seconds
Time After: 0.03264 seconds
Time Before: 0.03517 seconds
Time After: 0.03662 seconds
SET lastactivity = 1776544677, location = '/forums/private.php?do=newpm&explain=1&u=2613'
Time Before: 0.04965 seconds
Time After: 0.04998 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
Page generated in 0.048704862594604 seconds with 9 queries, spending 0.0080235004425049 doing MySQL queries and 0.0406813621521 doing PHP things.
