Time Before: 0.00137 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00227 seconds
Time Before: 0.00252 seconds
Time After: 0.00265 seconds
Time Before: 0.00360 seconds
Time After: 0.00681 seconds
Time Taken: 0.00321 seconds
Time Before: 0.00273 seconds
Time After: 0.01128 seconds
Time Taken: 0.00856 seconds
Time Before: 0.01323 seconds
Time After: 0.01367 seconds
Time Before: 0.01511 seconds
Time After: 0.01635 seconds
Time Before: 0.01259 seconds
Time After: 0.01652 seconds
Time Taken: 0.00393 seconds
Time Before: 0.02168 seconds
Time After: 0.02188 seconds
Time Before: 0.02430 seconds
Time After: 0.02560 seconds
End call of global.php: 0.027282953262329
Time Before: 0.02870 seconds
Time After: 0.02884 seconds
Time Before: 0.03092 seconds
Time After: 0.03238 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=26149', badlocation = 1
Time Before: 0.04484 seconds
Time After: 0.04524 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.043910980224609 seconds with 9 queries, spending 0.0089161396026611 doing MySQL queries and 0.034994840621948 doing PHP things.
