Time Before: 0.00176 seconds
Time After: 0.00255 seconds
Time Taken: 0.00079 seconds
Memory Before: 532.305 KB
Memory After: 557.422 KB
Time Before: 0.00262 seconds
Time After: 0.00327 seconds
Time Taken: 0.00065 seconds
Memory Before: 557.359 KB
Memory After: 558.367 KB
Time Before: 0.00346 seconds
Time After: 0.00360 seconds
Memory Before: 558.922 KB
Memory After: 559.445 KB
Time Before: 0.00441 seconds
Time After: 0.00720 seconds
Time Taken: 0.00278 seconds
Memory Before: 562.047 KB
Memory After: 562.969 KB
Time Before: 0.00367 seconds
Time After: 0.01069 seconds
Time Taken: 0.00702 seconds
Memory Before: 558.695 KB
Memory After: 1,639.742 KB
Memory Used: 1,081.047 KB
Time Before: 0.01284 seconds
Time After: 0.01328 seconds
Memory Before: 2,134.648 KB
Memory After: 2,135.266 KB
Time Before: 0.01647 seconds
Time After: 0.01768 seconds
Memory Before: 2,146.711 KB
Memory After: 2,146.570 KB
Time Before: 0.01213 seconds
Time After: 0.01797 seconds
Time Taken: 0.00584 seconds
Memory Before: 2,126.828 KB
Memory After: 2,259.922 KB
Memory Used: 133.094 KB
Time Before: 0.02354 seconds
Time After: 0.02368 seconds
Memory Before: 2,813.445 KB
Memory After: 2,813.961 KB
Time Before: 0.02652 seconds
Time After: 0.02775 seconds
Memory Before: 2,901.734 KB
Memory After: 2,902.328 KB
End call of global.php: 0.030539989471436
Time Before: 0.03231 seconds
Time After: 0.03268 seconds
Memory Before: 3,538.516 KB
Memory After: 3,538.945 KB
Time Before: 0.03550 seconds
Time After: 0.03693 seconds
Memory Before: 3,820.047 KB
Memory After: 3,821.734 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=26151', badlocation = 1
Time Before: 0.05101 seconds
Time After: 0.05126 seconds
Memory Before: 4,298.453 KB
Memory After: 4,298.680 KB
Page generated in 0.050113201141357 seconds with 9 queries, spending 0.0086441040039062 doing MySQL queries and 0.041469097137451 doing PHP things.
