Time Before: 0.03467 seconds
Time After: 0.03946 seconds
Time Taken: 0.00479 seconds
Time Before: 0.03957 seconds
Time After: 0.04000 seconds
Time Before: 0.04029 seconds
Time After: 0.04044 seconds
Time Before: 0.04120 seconds
Time After: 0.04383 seconds
Time Taken: 0.00263 seconds
Time Before: 0.04051 seconds
Time After: 0.04846 seconds
Time Taken: 0.00796 seconds
Time Before: 0.05661 seconds
Time After: 0.05697 seconds
Time Before: 0.05931 seconds
Time After: 0.06055 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05596 seconds
Time After: 0.06075 seconds
Memory After: 2,261.852 KB
Memory Used: 132.898 KB
Time Before: 0.10919 seconds
Time After: 0.10934 seconds
Memory Before: 2,815.430 KB
Memory After: 2,815.945 KB
Time Before: 0.51402 seconds
Time After: 0.51542 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,903.625 KB
Memory After: 2,904.219 KB
End call of global.php: 0.51793694496155
Time Before: 0.52908 seconds
Time After: 0.52925 seconds
Memory Before: 3,540.391 KB
Memory After: 3,540.820 KB
Time Before: 0.53266 seconds
Time After: 0.53408 seconds
Memory Before: 3,821.969 KB
Memory After: 3,823.656 KB
SET lastactivity = 1789129868, location = '/forums/private.php?do=newpm&explain=1&u=26300', badlocation = 1
Time Before: 0.55418 seconds
Time After: 0.55447 seconds
Memory Before: 4,287.875 KB
Memory After: 4,288.086 KB
Page generated in 0.55310106277466 seconds with 9 queries, spending 0.0082178115844727 doing MySQL queries and 0.54488325119019 doing PHP things.
